    just learned a bit about Amazon Echo - (
). Any chance to integrate it with HC2 ?
Is there a way to use the mail address? It seems that this is the default in how fibaro is approaching there accounts.
Quick question, trying to pressButton on a virtual device. Everything works in Postman and the HC2 API but I just can't get ha-bridge to work.
Type: HTTP Device
Target: http://<user>:<pwd>@<IP>:80/api/devices/<ID>/action/pressButton
HTTP Verb: POST
Body: { "args": [ 2 ] }
Content: application/json
It just won't work. Gives me a warning back. What am I doing wrong? Is it the '[ 2 ]' that messes up thingies?
Edited by sege
since i updated to the last ha bridge version i get the folowing error:
Could not find url: 1 for hue state change request: test from 192.168.1.39 body: {"on":false}
the ip mentioned is from my hue bridge but i put my hc2 ip number in the command.(complete diferent ip)
any thoughts?
On 2/10/2017 at 8:29 AM, gklein said:
i try
http://<name%40e-mail_domain_name>:<fibro_password>@<IP>/api/callAction?deviceID=<number>&name=turnOn
but i still getting a Login window.
I try different users but i am not able to Login to the api.
Heres  what I'm using.
Fibaro updates commands
http://name.lastname%40gmail.com:[email protected]//api/devices/ID/action/turnOn
On FIBARO, device type is "HTTP Device" and HTTP Verb is "POST"
http://username%40mail.com:pwd@ipaddress//api/devices/deviceID/action/actionName
some of the changes are:
no url off but Content Body Off
same for on
who has it running with the latest ha bridge?
same for on
ive had a few people saying that the 4.2.0 firmware the api format has changed slightly.
now you need the 2 // instead of 1 between ip address and the word api..
so personally i have stuck with 4.1.4
and the URL's are gone??
see picture
see picture
i have found that on occasion.
i go back to the bridge control tab and click 'bridge initilize' and that brings everything back again
My apologies, i was looking at my old cheat sheet, @morpheus75 is correct, this version did change.  a second / was added after the IP address. heres the most current scripts for the 4.2.0 ha bridge
Turn On a Device: http://USER%40EMAIL.COM:PASSWORD@IPADDRESS//api/callAction?deviceID=ID&name=turnOn
Turn Off a Device:http://USER%40EMAIL.COM:PASSWORD@IPADDRESS//api/callAction?deviceID=ID&name=turnOff
Dim a Device:http://USER%40EMAIL.COM:PASSWORD@IPADDRESS//api/callAction?deviceID=ID&name=setValue&arg1=${intensity.percent}
Start a Scene:http://USER%40EMAIL.COM:PASSWORD@IPADDRESS//api/sceneControl?id=ID&action=start
The Fibaro RGBW allows us to set the colours of all 4 values with this API:http://USER%40EMAIL.COM:PASSWORD@IPADDRESS//api/callAction?deviceID=241&name=setColor&arg1=100&arg2=200&arg3=50&arg4=0
   0
   0
it's not worling
please check the pictures to see what goes wrong
@akatar
where it says on items change type to 'http device'
under target item type in your api command
once done click on the green 'ADD' button first then goto top of page and click 'add to bridge'
see this video towards the end where i have demo'ed how to add our api commands
please use commands from post above as the api commands in the video is for habridge 4.1.4 and not the 4.2.0
in your screen captures, i dont see any of the URL settings have been completed.. I can only see that you have http device and post selected.  the video that @morpheus75 posted is the tutorial that i followed to set up my bridge.  he also has a video that he posted prior to this one is strictly on setting up the ha bridge from scratch.
im not familiar with javascript so i wouldnt know what to look for in your error log.. if you cant figure it out and your still stumped after watching the video, i know the developer at the github site is quite fast to respond to questions and he's helped me out of few issues that i had when i was setting up and updating the ha-bridge to current version.
26 minutes ago, morpheus75 said:
@akatar
thank you for all youre work,
but...
the error i get: spark.webserver.MatcherFilter
@akatar
im sorry i dont know how to fix that error.
best is to goto github and send message on there.
alternatively wipe micro SD card and start again... it should take about 20 mins to get back up and running again.
@morpheus75
no problem, it's running on a synology nas. i will erase docker and install it again
thank you for all youre time
Did it work to erase the docker and install it again akatar ? I do get the same error (I'm running it on a Ubuntu VM).
Edit:
Right.. I restarted ha-bridge completely and now it works..
Edited by Cafun
Hi Guys,
Thanks for all info in this topic. I have managed to install HA Bridge on my synology NAS via Docker and have setup light scenes that work with Alexa :) I was wondering if anyone has got a z wave boiler thermostat to work? I have a Secure wall thermostat and receiver in my config and would like to extend control to Alexa. Is this possible?
Gavin
Edit:
no it didn't :(
