    just learned a bit about Amazon Echo - (
). Any chance to integrate it with HC2 ?
And if you replace the @ for %40
Guest spazpeker
Did that for my email and it works fine
Yes indeed, forgot to mention it, but only for the email address:
to
to
Hi, thanks for the suggestion, but that still doesn't work, see below for the result. Any more help would be greatly appreciated.
username@testserver:~$ curl -v
[2] 4860
[1]   Done                    curl -v
username@testserver:~$ *   Trying 192.168.xxx.xxx...
* Connected to 192.168.xxx.xxx (192.168.xxx.xxx) port 80 (#0)
* Server auth using Basic with user '[email protected]'
> GET /api/callAction?deviceID=21 HTTP/1.1
> Host: 192.168.xxx.xxx
> Authorization: Basic hWRpa3NvZnR3YXJvQG91dG3vb2suY29tOkJvb3xvY2tzVG9zc25yNzY=
> User-Agent: curl/7.47.0
> Accept: */*
< HTTP/1.1 400 Bad Request
< Date: Mon, 26 Dec 2016 16:01:11 GMT
< Server: 0.9
< Cache-Control: no-cache, no-store, must-revalidate, max-age=0, max-age:0
< Content-Type: application/json;charset=UTF-8
< Pragma: no-cache
< Expires: Fri, 01 Jan 2010 00:00:00 GMT
< Connection: close
< Transfer-Encoding: chunked
* Closing connection 0
{"type":"ERROR","reason":"MISSING_PARAMETER","message":"name: missing required parameter"}
Authentication is working I see in the output (otherwise you would see a 401 instead of a 400).
Can you try:
curl -v
and after that (the & is replaced by %26):
curl -v
Can you try:
curl -v
curl -v
Hi again, the first suggestion failed but returned a list of device properties for the device ID:
curl -v
> GET /api/devices/21 HTTP/1.1
> Authorization: Basic YWRpa3NvZnR3YXJlQG91dGxvb2suY29tOkJvbGxvY2tzVG9zc2VyNzY=
> Accept: */*
< HTTP/1.1 200 OK
< Date: Mon, 26 Dec 2016 17:23:34 GMT
< Server: 0.9
< Pragma: no-cache
{"id":21,"name":"Main Ceiling Light","roomID":4,"type":"com.fibaro.FGD212","baseType":"com.fibaro.multilevelSwitch","enabled":true,"visible":true,"isPlugin":false,"parentId":19,"remoteGatewayId":0,"interfaces":["deviceGrouping","energy","levelChange","light","power","zwave","zwaveAlarm","zwaveMultiChannelAssociation","zwaveProtection","zwaveSceneActivation"],"properties":{"parameters":[{"id":1,"lastReportedValue":1,"lastSetValue":1,"size":1,"value":1},{"id":2,"lastReportedValue":40,"lastSetValue":40,"size":1,"value":40},{"id":3,"lastReportedValue":1,"lastSetValue":1,"size":1,"value":1},{"id":4,"lastReportedValue":0,"lastSetValue":0,"size":2,"value":0},{"id":5,"lastReportedValue":1,"lastSetValue":1,"size":1,"value":1},{"id":6,"lastReportedValue":1,"lastSetValue":1,"size":2,"value":1},{"id":7,"lastReportedValue":1,"lastSetValue":1,"size":1,"value":1},{"id":8,"lastReportedValue":5,"lastSetValue":5,"size":2,"value":5},{"id":9,"lastReportedValue":1,"lastSetValue":1,"size":1,"value":1},{"id":10,"lastReportedValue":0,"lastSetValue":0,"size":2,"value":0},{"id":11,"lastReportedValue":255,"lastSetValue":255,"size":2,"value":255},{"id":13,"lastReportedValue":0,"lastSetValue":0,"size":1,"value":0},{"id":14,"lastReportedValue":1,"lastSetValue":1,"size":1,"value":1},{"id":15,"lastReportedValue":30,"lastSetValue":30,"size":1,"value":30},{"id":16,"lastReportedValue":5,"lastSetValue":5,"size":2,"value":5},{"id":19,"lastReportedValue":0,"lastSetValue":0,"size":1,"value":0},{"id":20,"lastReportedValue":1,"lastSetValue":1,"size":1,"value":1},{"id":21,"lastReportedValue":0,"lastSetValue":0,"size":1,"value":0},{"id":22,"lastReportedValue":1,"lastSetValue":1,"size":1,"value":1},{"id":23,"lastReportedValue":0,"lastSetValue":0,"size":1,"value":0},{"id":24,"lastReportedValue":0,"lastSetValue":0,"size":1,"value":0},{"id":25,"lastReportedValue":0,"lastSetValue":0,"size":1,"value":0},{"id":26,"lastReportedValue":0,"lastSetValue":0,"size":1,"value":0},{"id":27,"lastReportedValue":15,"lastSetValue":15,"size":1,"value":15},{"id":28,"lastReportedValue":0,"lastSetValue":0,"size":1,"value":0},{"id":29,"lastReportedValue":0,"lastSetValue":0,"size":1,"value":0},{"id":30,"lastReportedValue":2,"lastSetValue":2,"size":1,"value":2},{"id":31,"lastReportedValue":1,"lastSetValue":1,"size":1,"value":1},{"id":32,"lastReportedValue":2,"lastSetValue":2,"size":1,"value":2},{"id":33,"lastReportedValue":0,"lastSetValue":0,"size":1,"value":0},{"id":34,"lastReportedValue":0,"lastSetValue":0,"size":1,"value":0},{"id":35,"lastReportedValue":1,"lastSetValue":1,"size":1,"value":1},{"id":37,"lastReportedValue":1,"lastSetValue":1,"size":1,"value":1},{"id":39,"lastReportedValue":250,"lastSetValue":250,"size":2,"value":250},{"id":40,"lastReportedValue":3,"lastSetValue":3,"size":1,"value":3},{"id":41,"lastReportedValue":2,"lastSetValue":2,"size":1,"value":2},{"id":42,"lastReportedValue":3,"lastSetValue":3,"size":1,"value":3},{"id":43,"lastReportedValue":1,"lastSetValue":1,"size":1,"value":1},{"id":44,"lastReportedValue":600,"lastSetValue":600,"size":2,"value":600},{"id":45,"lastReportedValue":1,"lastSetValue":1,"size":1,"value":1},{"id":46,"lastReportedValue":1,"lastSetValue":1,"size":1,"value":1},{"id":47,"lastReportedValue":1,"lastSetValue":1,"size":1,"value":1},{"id":48,"lastReportedValue":1,"lastSetValue":1,"size":1,"value":1},{"id":49,"lastReportedValue":1,"lastSetValue":1,"size":1,"value":1},{"id":50,"lastReportedValue":10,"lastSetValue":10,"size":1,"value":10},{"id":52,"lastReportedValue":3600,"lastSetValue":3600,"size":2,"value":3600},{"id":53,"lastReportedValue":10,"lastSetValue":10,"size":2,"value":10},{"id":54,"lastReportedValue":0,"lastSetValue":0,"size":1,"value":0},{"id":58,"lastReportedValue":0,"lastSetValue":0,"size":1,"value":0},{"id":59,"lastReportedValue":0,"lastSetValue":0,"size":2,"value":0}],"pollingTimeSec":0,"zwaveCompany":"Fibargroup","zwaveInfo":"3,4,5","zwaveVersion":"3.4","RFProtectionState":"0","RFProtectionSupport":"3","alarmLevel":"0","alarmType":"0","configured":"true","dead":"false","deviceControlType":"23","deviceGroup":"[]","deviceGroupMaster":"0"* Connection #0 to host 192.168.0.53 left intact
,"deviceIcon":"15","emailNotificationID":"0","emailNotificationType":"0","endPointId":"1","energy":"2.75","isLight":"true","liliOffCommand":"","liliOnCommand":"","localProtectionState":"0","localProtectionSupport":"5","log":"","logTemp":"","manufacturer":"","markAsDead":"true","model":"","nodeId":"4","parametersTemplate":"698","power":"16.70","productInfo":"1,15,1,2,16,0,3,4","protectionExclusiveControl":"0","protectionExclusiveControlSupport":"false","protectionState":"0","protectionTimeout":"0","protectionTimeoutSupport":"false","pushNotificationID":"0","pushNotificationType":"0","remoteGatewayId":"0","saveLogs":"true","sceneActivation":"0","serialNumber":"h'0000000000003f91","showEnergy":"true","smsNotificationID":"0","smsNotificationType":"0","useTemplate":"true","userDescription":"","value":"99"},"actions":{"reconfigure":0,"reset":0,"setValue":1,"startLevelDecrease":0,"startLevelIncrease":0,"stopLevelChange":0,"turnOff":0,"turnOn":0},"created":1482591177,"modified":1482591177,"sortOrder":20}username@testserver:~$
curl -v
should indeed return the device, so that concludes the authentication is working now.
What did curl -v
(with the & replaced by %26) return?
6 minutes ago, boerremk said:
curl -v
What did curl -v
Yeah sorry for the pauses in between, dealing with kids requests at same time lol. The second part also failed but slightly different....
curl -v
> GET /api/callAction?deviceID=21%26name=turnOn HTTP/1.1
> Host: 192.168.0.53
> Accept: */*
< Date: Mon, 26 Dec 2016 17:46:51 GMT
< Server: 0.9
< Pragma: no-cache
< Connection: close
{"type":"ERROR","reason":"WRONG_TYPE","message":"deviceID: expected unsigned int"}testuser@server:~$
Just to re-iterate all the commands you have sent me, work from my web browser on my normal pc AFTER I have manually authenticated. I think you are close.
Change that statement: The last one didnt, it too failed with the expected unsigned int, so it obviously doesnt like the %26 instead of the &.
When I ran the one whereby I only replaced the @ with %40 this worked on the web browser, the reply was:
But not on the server.
Just doesn't seem to like the "name=turnOn" bit
If I leave the "name=turnOn" bit, it complains that it isn't present:
< Date: Mon, 26 Dec 2016 18:00:02 GMT
< Server: 0.9
< Pragma: no-cache
< Connection: close
I have tried "name=1" and "name=0" instead of "name=turnOn" with no success.
I have also tried "name%3DturnOn" and it replies with this:
< Date: Mon, 26 Dec 2016 18:05:02 GMT
< Server: 0.9
< Pragma: no-cache
< Connection: close
{"type":"ERROR","reason":"MISSING_PARAMETER","message":"name: missing required parameter"}name%3DturnOn: command not found
I have tried putting the parameter in '' marks so name='turnOn' and also replacing the & with different characters such as : and I have also tried adding on / after address again with no success.
Edited by TrevorNewsome
What happens if you  try it on the habridge (with the %40 instead of the @)?
Quote
"Change device state, Could not send data for network request:
with Message: HTTP request may not be null"
is the error returned in the HA Bridge log file.
By the way I really appreciate your help.
Can you set "Http verb" to GET
EXCELLENT, thank you so much, it now works, I had tried GET before but obviously not whilst also using the %40.
I'm busy working to get the Echo the job done. I succesfully installed the RPI and HA-Bridge. If i manually add a device, the Echo does see it, but if I ask to turn the lights on the Echo responds with: Sorry, the device XXXXX is not responding.
When I see the other tutorials/video's, I saw that when the device was manually added the device has a random number at bridge control. But if I manually add a device it's just counts up from 1. (see pictures)
I tried to change the e-mail with %40 and also created changed it to a user without e-mail like admin. But that wasnt the solution. Any help?
Edited by pnutp0wer
Added info
hi
apologies if i am telling you stuff you already know but the code in the URL above should be no spaces.
also
http://me%[email protected]/api/callAction?deviceID=80&name=turnOn
or
http://user:[email protected]/api/callAction?deviceID=80&name=turnOn
Also
hi try this. forget all devices in alexa press save and re-initialise in habridge then scan for devices again in alexa this refreshes everything. also make sure that the habridge and alexa are both online aswell as the hc2 is accessible. another test to make sure that the API code is correct is just to press Turn On Turn Off within habridge. this makes sure the communication between habridge and hc2 is ok cheers
I'm also asking for help,
my On URL is http://user%40yandex.ru:[email protected]/api/callAction?deviceID=29&name=turnOn
Off URL is http://user%40yandex.ru:[email protected]/api/callAction?deviceID=29&name=turnOff
HA Bridge log is
Change device state, Could not send data for network request: http://user%40yandex.ru:Password1@192.168.1.2/api/callAction?deviceID=29&name=turnOn with Message: HTTP request may not be null
in case I add Http Verb - GET
Content Type - text/html
Content Body On http://user%40yandex.ru:[email protected]/api/callAction?deviceID=29&name=turnOn
Content Body Off http://user%40yandex.ru:[email protected]/api/callAction?deviceID=29&name=turnOff
I don't get any warnings in HA Bridge log,
nothing happens and device doesn't turn ON
works right in browser, turning on
please help me to make it work!
Edited by DePo
HA Bridge log is
You have to set the On URL, the Off URL and the Http Verb to Get, the rest should not be changed (so Content Type can be left to Please Select, other fields should be empty). That is it.
I do like this, but
PS with same settings it was working right before I update to 4.110, and change "admin" to "[email protected]"
Edited by DePo
Hmmm strange, the settings looks ok. I also use 4.110 with the [email protected] user and is working without a problem.
Just to be sure: you replaced the @ for %40 I asume?
yes,
it was http://user@yandex.ru:[email protected]/api/callAction?deviceID=29&name=turnOn
now is http://user%40yandex.ru:[email protected]/api/callAction?deviceID=29&name=turnOn
