sbowtell 0
I’m relatively new to Lua and Fibaro. I have two questions about running Lua functions and accessing Lua tables from other scenes.
Running Functions From Other Scenes:
I have built a scene called "Initialise" which contains a collection of Lua functions. One of these functions is called Arm() and takes the parameter "_status" which indicates how the Intruder Detection System should be set. The "_status" can be:
Disarm = disarms all motion sensors, door and window sensors
Away = arms all motion sensors, door and window sensors
Home = arms all the door and window sensors downstairs (does not arm motion sensors or upstairs window sensors)
I want to call this Arm() function from other scenes, for example I want a scene called "Arm Away" which has a single line of Lua Arm("Away"), and another scene called "Arm Home" which has a single line of Lua: Arm("Home") and another scene called "Disarm" which has a single line of Lua Arm("Disarm"). This way I can have different scenes available to the user which are used to set the Intruder Detection System but I don't need to replicate the same code in all three scenes.
Unfortunately this doesn't work. Although I run the “Initialise” scene which contains the Arm() function (but doesn’t contain any code to call the Arm() function) when I try to run my “Arm Away” scene (which contains a single line of Lua Arm(“Away”)) I get a message saying
[ERROR] 12:59:57: line 1: attempt to call global 'Arm' (a nil value)
Accessing Tables From Other Scenes
I am trying to develop portability into my Lua code for home automation. One of the reasons for this is I have a Fibaro system in two houses and so having generic code which can just be ported into another Fibaro environment does not require any recoding is a real advantage. Another reason is so that if I add a new motion sensor to my house I don't need to change any code to make sure it is included in the code to Arm all the motion sensors.
The way I achieve this is by naming all the zWave devices according to a standard. For example: M0_HALL_MS_01 is the first motion sensor in the Hall on the ground floor of the Main House, G1_BED2_WS_02 is the second window sensor in Bedroom 2 on the first floor of the Guest house. By building a table in Lua of all the devices I can work through that table looking for devices with “MS” in the name when arming all the motion sensors.
So to the question – can I make this table of devices available to other Scenes (not just the “Initialise” scene which was used to create it?). I know how to use Fibaro Global Variables to make data available to multiple scenes but my question relates specifically to a table.
I tried to research this online and from what I understand a Lua variable is local to a function unless it begins with “g_”. So my devices table is called g_devices. When I try to access this table from another scene I get a message saying
[ERROR] 13:01:12: line 1: attempt to index global 'g_devices' (a nil value)
I'd be grateful for any assistance or pointers anyone can provide.
8 answers to this question
