hi,
i am browsing several forums in order to find an answer, as i don't find any, here is my post.
i have servral electrical and water devices that generate pulses on consumption. this is called S0
for instance, the electrical modules generate 1000 pulses by kwh, and the water meter generates 1 pulse by 0,25 l
i would like to know if it exists a zwave counter that listen to these pulse, or if we can use the fgbs321 with lua code to listen to the pulses, but i don't know if zwave can be quick enought to react to several pulses per second.
how would you do that ?
thank you
yves
I do not have knowledge of any Z-wave device (however I might be wrong) that would be capable of reading such short pulses. Do these devices have some visual indicator of the usage? Then check out Northq modules. Otherwise I would advise DIY solutions, like Arduino with Ethernet shield for example.
The NorthQ reader is indeed available for both energy and gas, not sure if it is available for water. These count pulses of for instance 100.000 pulses per kwh.
  • 3 weeks later...
I have the NorthQ NQ-9021 and it is supported by HC2, works fine. However, only basic functions are supported, yet. For now there are no apparent way to include the sensor in the eg Energy Panel which off course would be of great value if implemented.
  • 3 months later...
Do you have a VD you can share for the NorthQ readers?
Regards
Hello!
Sorry, I have not been into here for a while and I have apparently not seen the forum notification. Anyway, here is the VD:
local meterID=156
function getIcon(watt)
  if(watt > 8000) then return 149
  elseif(watt >= 7000) then return 148
  elseif(watt >= 7000) then return 147
  elseif(watt >= 6000) then return 150
  elseif(watt >= 5000) then return 146
  elseif(watt >= 4000) then return 145
  elseif(watt >= 3000) then return 144
  elseif(watt >= 2000) then return 143
  elseif(watt >= 1000) then return 142
  elseif(watt >= 500) then return 141
  else return 141 end
function round(num, idp)
  local mult = 10^(idp or 0)
  return math.floor(num * mult + 0.5) / mult
--Main start
e1=fibaro:getValue(meterID, "value")
t1=os.time()
etot=round(261009 + e1*0.01)
while e1==fibaro:getValue(meterID, "value") do end
e2=fibaro:getValue(meterID, "value")
t2=os.time()
td=t2-t1
ed=(e2-e1)*3.6
p=round(10000*ed/td)
fibaro:call(149, "setProperty", "ui.Label1.value", p.." W")
fibaro:call(149, "setProperty", "ui.Label2.value", etot.." kWh")
fibaro:call(149, "setProperty", "currentIcon", getIcon(p))
  • 7 years later...
2738 days since the last post ... a good day to ask for an update ... is there any news wrt reading the impulse output from an electricity meter? Any new devices or more clever solutions? Did not find something at the first glance, and the link above is also no longer existing.
Edit: Just found
here from 2021 ... will check if it helps already ...
Edit 2: No, it does not really help. I saw that the Smart Implant was mentioned there and was wondering how that could work. But it obviously does not. At least not for electricity where you have too many pulses per second for high loads. And anyways, you would still need a sensor which get the actual pulses from the meter LED.
So the question is still open ;)
Edited by krza
