marcfonteijn 4
I have been struggling for the past few days to make the UBS work with a very basic motion sensor. The UBS and the motion sensor are hooked up to a 12v adapter. IN1 is connected to the LOAD terminal of the motion sensor. I've setup Parameter 3 in HC2 to be a Normal Open.
My problem is that the UBS is always indicating a breach. It never goes into a non-motion state...
The only way I can force the UBS into non-motion state is by connecting IN1 to GND on the motion sensor.
What I've noticed is that the voltage on IN1 is 2.75v by default. This is also the voltage on the LOAD terminal when there is no motion.
So what I'm guessing is that because the motion sensor doesn't connect LOAD to GND in a non-motion state the UBS never goes into a non-motion state... The answer is probably pretty simple but what should I do in this case to make the UBS work in this setup?
I'm 100% sure the motion sensor work because I've check with a multimeter what happens on the LOAD terminal when it switches. The voltage on the LOAD terminal rises to 12.5v.
The setup is very basic and the attached photo should tell whole story.
13 answers to this question
