Gardena 24V irrigation valve
Hi
Has anyone tried to integrate Gardena 24V valve like this one
  with fibaro? I will have 3 valves and thinking how to best deal with it? Would it be possible to controll them with RGBW controller and integrate into sprinklers panel?
I will have also main valve 230V that i could integrate with Siprinkler if RGBW would not be possible so integration is not an issue (I can controll the RGBW separately) - would just need to know if RGBW would work with this Gardena Valve
That ac adapter will work
The IN and O1/O2 terminals of the Fibaro unit are connected directly to the relay, so you can drive 24V valves with it
This is from the manual of ver 1.4-1.7
110 - 230 V AC ±10% 50/60Hz 24-60V DC ±10%
So no you cant use 24V AC to power the fgs221
I use fgs222 and use 230V and 12V DC to my sprinklers
    UPDATE: or actually same question on Gardena 9V valve as well
     as it looks like this one may be needed
    Anyone? Gardening company will come any day soon
    Hi
    RGBW would work, but you would need a relay whith a flyback diode between the RGBW and the Gardena. This would do nicely.
    Or you could use a pair of Fibaro FGS221, they run nicely on 24VDC
    Thanks! But i thinking this 24v valve is AC, would it stil worki with fibaro relay?
    Well... technically i assume that the fibaro relay just has a rectifier bridge that passes to a small linear regulator
    So, while the spec does not support 24VAC, and I have not tested it... it should work
    But else a RGBW + AC/DC-converter + a relay board should work
    My friend has 24 v Ac on his rainbird valves and it works just fine.
    He use fgs221 not rgbw.
    With rgbw you can not use the sprinkler panel.
    thanks. I understand I need sort of step down from 230 to 24Vac first right?
    Yes you need to do that.
    google "ac adapter" and you will find lots of it.
    Something like this will do?
    And one more - do you power the Fibaro Relay switch off 24VAC? the manual does not say it would be supported/
    Ok so i will power fgs222 with 230V and then separately drive the valves with 24VAC, got it - thanks
    can i power fg222 with 24DC and then drive valves with 24ac?
    NO
    230V
    /emoticons/default_smile.png" alt=":)" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" /> I accept this but out of curiosity - why not? You can drive fg222 with 24VDC in normal scenario
    Anyhow, thanks for help
    FGS222 has not 24Vdc, but FGS221 has it, but FGS221 is banned in Sweden so i cant use it,
    But 24Vdc is not 24Vac, and your valves is ac,
    From the manual on FGS221
    Power supply:110 - 230 V AC ±10% 50/60Hz 24-60V DC ±10%
    From manual on FGS222
    Power supply:110 - 240V ~ 50 - 60Hz
    I ended up with a slightly different setup. Since I have 3 valves, I used one 3kw Relay and one 2x1.5 relay. I used similar wiring diagram as in this post
    but with a slight twist:
    1. I power the relay shutters with 24V DC power adapter (from my old scanner). Water and 230V just does not go hand in hand for me
    2. I power the valves with 24V AC power transformer with one wire connected to I on the relay switches and the other wire connected to the valve
    3. Second valve wire goes to O on the relays.
    Prototype photo attached (be generous - I am an IT architect, not electrician  LOL )
    I think it looks just fine.
    Have you test it snd it works?
    You wrote Water and 230V just does not go hand in hand for me, not for me eather. I got my FGS222 in the garage and the valves in the garden. Just the cable with 12Vdc goes to the valves in the garden.
    Tested OK, valves open and close as desired. Many thanks for all your inputs
    Im just happy that i coluld help someone.
    I got a lot of help from this forum.
    Hi all,
    I was wondering why the RGBW Relay cannot be used as a actuator for the sprinklers, at least not in the sprinkler panel?
    Are there any plans to do that, because for 3 sprinkler zones you need at least 2 usual relays where you could use one RGBW relay also for the Rain-sensor input?!
    Cheers
    joystick
