Hey,
How can i associate rgbw devices with each other? like i want to change the colors of the led's from a single touch and set programs to work together.
  • 1 month later...
Hi
You need to use association group 5 and only select one RGBW device. You can daisy chain the associations.
Hi
Are you sure about that. The official RGBW manual says the following:
"V association group reports device status. Only one device may be assigned to this group, main controller by default. It's not recommended to modify this group's settings."
I use this, not my code.
