RiccardoCanetta 13
Hi
after upgrade to 4.056 (from 1.x) I have the HC2 randomly assuming a 0 degrees temperature from Everspring ST814 sensor - I mean that HC2 shows 0 degrees in the room, but if I go in front of the sensor, the temperature is correct (20.20 for example). HC2 only gets again the right value after 30 minutes or if I manually wake up the sensor (triple click)
You can see in last night log (attached) an example:
- 00.14 temp goes from 20.10 to 0.00, heating starts
- 00.44 temp goes back to 20.60, heating stops
I have 7 x ST814 and it happens with all of them, so I tried to do a "soft reconfig" of the sensors and a reboot of the HC2 but it still happens, randomly
Is this a bug I should file with bugzilla or is there something else I could try?
Riccardo
7 answers to this question
