Derek1948 1
I'm new to this, so patience.
I have 2 SRT321 Secure Thermometer with a Home Centre Lite. The electric heaters will be switched with fibaro relays. The HCL says it has configured the thermostats and I can see that the temperature reading from them shows, but changing the 'set' temperature on the thermostats does not change the HCL set temperature.
I want to control the room temp. from the thermostats most of the time, so this is quite critical.
HELP!
