Repeat / until loop not working, need help
Guest samuelboerhoop
When I plugin the plug in the power socket from my denon receiver, internally the unit is initializing different settings, like network, etc...  when i plugin the unit, the receiver is set to standby, ok. I want to make a lua code whereby it makes a loop with repeat / until...until i get a code back from the unit if it's in standby mode, or on mode, from there it should continue, see below. but it's skips the repeat/until... When the unit is plugged in, no code is been returned... So i was thinking:
instead of this: "if not(trim(result) == "PWON" or "PWSTANDBY") then"
use "if (trim(result) == """) then"
Are there other ways to detect an empty string ?
With other words:  When no code is been returned, stay in this loop until PWON or PWSTANDBY is been returned.
Please some help would be appreciated. Thankss a lot
13 answers to this question
I guess it should be like this:
Alex is right.
Both are valid lua. Let's see what these expressions print:
Result:
PWSTANDBY
false
  • I changed the result to
    if not(trim(result) == "PWON" or trim(result) == "PWSTANDBY") then
    See photo from the debug button.
    The denon receiver is unplugged, so no data should return. but still it skips the loop ??
    How come...?
    It should say:
    denon receiver... (result)
    ... is Initializing
    loops for every 3 seconds, case on top you have a 2second sleep and after iif not line.. = 1 second
    but the result is as the photo, ones you press the button...
    more suggestions ?
  • ok, now i got the following:
    i changed the "until" line to:
    until (trim(result) == "PWON" or trim(result) == "PWSTANDBY")
    now my debug gives me, see photo
    now it goes in endless loop, until i plugin the receiver
    but because action is false ... it should tell me
    Denon receiver... (result)
    ... is Initializing.
    this should be the loop, why not?
    Did you change both lines that were wrong?
    and
  • Yes, as in:
    I've reworked the script a bit, so it has some more error checking plus error checks. I can't test it on a real Denon, but I can simulate it. So could you please give it a try?
  • I tested your code: this is the result...
    First i restarted the HC2. to start from scratch.. (clear memory)
    situation - denon receiver is unplugged
    See photo, when i press start in debug... no code is been generated for the first time..
    Press the button: see photo
    see next photo = 3 times pressed the button
    hope to hear from you again
    Thanks already
    I see. I think the repeat-until is working now... But the tcp socket error 2 is not good... In any case it means the TCP/IP communication failed. How sure are you about address, port and command sent to the Denon? Is the sleep right above the read() sufficient? I don't have a lot of experience with that, but I'll see what I can find out.
    Right. I misunderstood something. So you really want to power off the Denon, so actually "socket error 2" is in this particular case not an error, but an indication that you should "keep trying". Usually you want to abort the loop, but here it's actually not a failure.
    Just replace the "break" statement with:
    initialized = false
    Now I expect the script keeps printing "socket error" in a loop, until TCP/IP of the receiver is working. Then it should start checking for "PWON" or the other thin.
    Does this make sense?
  • As i mentioned : situation - denon receiver is unplugged, i am working from the office, by means of teamviewer. the denon receiver isn't plugged into the 230V, that's why I get a time out. Will have to test it when i am home again
    I did a search on error 2 also - find out it was a timeout , ip + port address are correct
    what happened when I increase tcpSocket:setReadTimeout(1000); to tcpSocket:setReadTimeout(10000) ?
    Because normally it takes about 30-40 seconds before the denon receiver is returning data on the network bus to the hc2. So when i activated the button after the power from the denon is been switch on (standby mode), after that it takes around 30-40 seconds before i got a respond from the denon.
    Will let you know by asap if it works.
  • behind the denon receiver i am using a wallplug from fibaro, with some other equipment connected to it.
    When i turn on the wallplug then the denon receiver gets 230V and in a scene this button is been pressed... while it waits until the denon is been initialized > then it will turn on the receiver > selects the input and sets the volume.
    When the denon is on or in standby when its been initialized then it skips the repeat/until, because it returns with PWON or PWSTANDBY.. status and follows the rest of the code... etc....
    That's the idea behind it... if this loop repeat / until is not there i have to press the scene for a second after the denon is been powered up for a second time.. you got it?
    Yes, understood, and that's what this VD code will do. There's maybe one improvement to be done. If the receiver doesn't come online, for example because it's not plugged in, this code will keep looping. I think counting the number of tries and breaking the loop after X attempts + a status label on the VD might be a good idea.
