tvs 1
I thought I would share some new on the 25.25 firmware for the RGBW module...
I've got three of these modules, two have firmware 22.22 which works perfectly in every-way I use it (Just with single colour LED strip), the Third module is running the newer Firmware 25.25
The Module running 25.25 has a bug in the firmware which doesn't allow it to be probably controlled over association. Basically it will always switch on at 1-5% brightness from association. You can still dim up, dim down, switch off, double click etc... but it will ALWAYS come back on at 1-5%.
I've been speaking to Fibaro Tech support (Slowly) and thereby basically said there is no cure for this.
I just thought I should share this as others may have the same problem. The e-mail chain from Fibaro is below:
