cjard 1
Hi all
I didn't find any way to program my network in the app. I have a hcl, and it is recognised.. Serial number is there in app and everything, and app is telling me power consumption data but it is telling me I have 0 lights so I'm confused.. App seems to understand I have some devices because they are consuming watts, and it draws graphs, but when I try to find those devices in the app it tells me there are none. If I go into rooms in the app, it correctly tells me I have a Lounge, that I have configured on the hcl web page, and it says the lounge is consuming 23watts.. I believe it. When I press the toggle in the app to turn the lounge off , the bulbs remain on, but the app says it is consuming 0 watts
Right now I have just one dimmer plugged into a light and it is on my table, I'm testing the system and learning about it
If I use hcl webpage in Safari on my iPad i can see my dimmer and turn the bulb on and off, but it says 0 lights in the app..why the different information?
So do I use the web page of hcl to set up my network and the app can only view it? Where do I find my dimmer in the app? Is the app just a reporting tool and that turns the report on and off? It's kinda useless to me if the app can't do anything like turn devices on and off/configure stuff. Using the web page is painful on an iPad because for example you can't drag the slider to vary the bulb brightness, it just drags the webpage around
