Is there a simple way to get current wanted temperature in Heating Panel Zone?
Like in /api/panels/heating where you get manual set temp. and expiry timestamp and holiday temp., but not fall-back temp if none of those are active.
Without calculating day hour timestamp timer ... from /api/panels/heating/ID
Otherwise I will do a LUA that will calculate the temperature for all zones and set them to variables every x seconds - but that means delay and script running all the time.
FIBARO why not add in "Linked Devices > Heating" - Variable - that would show wanted temperature. (Main Device, Switch 1, 2..., Variable Current temp, Wanted Temp ..., Hysteresis )
this would solve also "timmeeh" problem in
I want to calculate the temperature of water going into (forward) the Floor heating or Radiators.
Depending on the:
- To - Outside temperature (or average of last few hours)
- Tc - Current temperature of the zone (maybe average of all temperatures in rooms in the zone)
- Tw - Wanted temperature of the zone
maybe also if it is sunny or not, for some zones with lots of windows, with outside Motion Sensors Lux meter.
The most weather control "professional" regulations, that I'm working with, are calculating with "Heat curve":
For heating system:
floor 0,2 - 0,8
wall 0,4 - 1,0
radiator 0,8 - 1,4
calculation is something like this:
Tr - room temperature
Hc - Heat curve factor (0,2-1,4)
Lift - rising whole curve  =20 +-5 depend on the insulation that you have
(Tr - To) * Hc + Lift = Tfw  - temperature of the water going into radiators of Floor heating.
I will add also calculation of difference between Wanted and Current temperature in the room so water temp. gets lower when approaching Wanted temp.
Also with measuring difference between temperature of forward water and returning water we can calculate the current temperature need of the floor.
With the highest of the required water temperatures I can set Heat pump to heat only to that temperature (+ few degrees)
