Fibaro Dimmer 2 Version 3.3
Guest AxelS
anyone already had this new Dimmer up and running? There is no template in 4.057 - I´m not able to use it in scenes or set association on it.
I mean, this is a strange behavior, that Fibaro doesn´t "know" their own modules?!
/emoticons/default_icon_confused.gif" alt=":-?" />
Best
Axel
AxelS, please contact support - they will help you resolve your issue ASAP.
Received mine 2 days ago and they are working properly untill now.
I'm able to associate them.
Not tested scene-activation
Best
Axel
Did you install a load? this is needed for load calibration. The wireless signal is deactivated until the first calibration.
Device seems to be working properly (with a load, indeed).
Had a quick stab at sceneActivation (really quick) and after setting p28=1 and even (soft) reconfigure i don't get scenaActivation in "/api/devices". I'm thinking that an updated template would do the trick, but I am not going to ask support because at the moment I don't really need it.
Guest AxelS
    Yes, load is there. I'm also able to switch on the lights remotely but I'm not able to set an association on it.
    I also have no template for the device.
    Fibaro is aware of the problem and said that I have to wait for the next version or give them remote access.
    So, I'm waiting ...
    next version of dimmer or hc2 ?
    For association, in my case it works (endpoint 0, group 5, M) from a 212 V3.2 to 212 V3.3 (this one without switches connected on s1 and s2)
    Please double check if your dimmer is not in secure mode (it's added in secure mode by default when the device is added trough the mobile app)
