Roy 0
Hi
I have some issues starting a scene which I start by using my tasker app.
The scene works as follows:
1. When I leave my home, my phone will disconnect from my wifi
2. After it is disconnected, a notification will pop-up and asks "Activate or Deactivate your alarm?"
3. When I push the button "activate", my fibaro alarm scene will start and my home alarm is activated.
When I start the scene wihtin my personal (wifi) network, its works fine, but when I turn off the wifi connection and change the ip-address to the external ip-address of my Ziggo Ubee modem, it doesn't work anymore.
I have tried:
- several attempts of port forwarding in de the modem
- static IP in HC2
- change DNS in HC2
Someone any idea?
1 answer to this question
