Last week I got 2 x FGD212 dimmers, 3 x Popp 123850 plug dimmers and 1 x WallC-S2 wall controller.
Before I received the HC2, I used the wall controller as primary controller on all 5 dimmers, both dimming and on/off worked like it was supposed to, with buttons 1 and 3.
Now I've set up the HC2, with the wall controller as a second controller, working with the Popp dimmers through association, still with buttons 1 and 3, and have no problem what so ever. I'm still able to dim and switching on/off.
Inclusion of the FGD212 dimmers went smoothly, and they can be controlled from HC2, even from within scenes triggered by the wall controller.
What I can't do, is use the "Switch On/Off and Dim (send Basic Set and Switch Multilevel)" I currently have working with the Popp dimmers, with the FGD212s.
I've associated them in the same manner as the ones working, but get no feedback from the FGD212s.
I have searched all over for similar problems, but can't seem to find anything.
Is it a parameter that needs to be altered to get it working like it was without the HC2?
Any help is appreciated!
PS: As of now I'm using HC2 ver. 4.058 beta, but I've also tried 4.057 beta and 4.056.
