These look very smart!
yeah, saw the ad today. they look great. to think i drilled holes in my steel door to insert a darn aeotec sensor that has never worked on my HC2...
Review. (In swedish)
I have tried them... they work good BUT at least in my house it was really hard to find a place where they fit. I bought 2 and just found 1 window where I could use them, in all the doors they were to big to fit in between the door. If you have space then they are really hidden if you don´t I would use the fibaro door sensor and get an additional temp meter as well
    Fibaro sensors do not like being outside
    Just installed one today outside, for the moment it's doing the job.
    give us feedback how it working outside because there is no specification for this product, on device there is no IP55+, there is no information about in what temperature device can work. And that information about 10 years on battery is a bit like joke
    Why is 10 years battery life a joke? Many companies make elaborate claims your hardly in a position to comment on other companies products! Be fair to others hey?
    A.Socha from what I read it can work from -30 to +80 just says that it can work outside with no more specification. Do agree with you about the 10 years of battey live looks a little bit strange, and it can not be changed, will see... the inclusion is ok with the box it's recognized has a usual door sensor + a motion sensor always triggered.
    If you want to connect to have a look just tell me.
    That motion sensor is tamper. So you can hide it
    yes, but they got bigger battery and they are not work outside using z-wave, to be fair lets wait for feedback
    how much from that 10 years we gonna have
    Thank you A.Socha, that's what I did. I for sure let you know about it lifetime.
    My Fibaro doorsensor is installed in my mailbox, so it's protected from rain, but not from moisture and minus-degrees.
    (I installed it over a year ago, so the sensor is on it's second winter.)
    Will survive that... It seems to be UV light that breaks them.
    I had 2 that became brittle and broke apart.
    These strips are working well up to now! Good range aswell...
    Here is my review:
    I am also wondering about the 10 year battery life but what the heck, with some knowledge it is rechargeable...
    Here is my review:
    rechargable? are you sure?
    It has a vbat+ and a vbat- terminal at the back of the pub so I assume so.
    I could be wrong but I've never heard of a rechargeable battery that would keep charge for several years. Discharge rates are (rule of thumb) 10 x higher than that of non-rechargeable cells designed for long shelf life.
    I'm quite convinced these are not rechargeable
    /emoticons/default_smile.png" alt=":)" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" /> please do let me know pathduck i would be SOOOOOOO happy if that is the case as i think i have one that is a bit iffy anyway showing only 25% power!
    I am sorry, it does in fact look like it is a disposable battery, i have at least not been able to find one that size which is not. I will update my post with the new info, i thought it was re-chargeable as the battery terminals were visible. This is probably to let people change the battery.
