mrtn 5
Hi all
I am trying to create a scene that changes the setpoint temperature of my Nest thermostat to 10 degrees after windows have been opened. I want the setpoint temperature to be set back to its previous setting once windows are shut.
The first part is easy as I have used IFTTT with a Maker channel. But it doesn't look like it's possible to set it back to previous setting through IFTTT.
I have the Nest plugin installed which works fine and when I create a new LUA scene, the only action event is 'SetMode' and looks as follows:
Unfortunately there is not too much information available on this so any help would be much appreciated.
