Hi all,
I'm writing a scene for full automation of windows blinds.
I need to check a value against all the values in a table if it is smaller or not.
So far I have come up with:
local StateAll = { }
  StateAll = { value1, value2, value3, value4, value5, valu6, value7, value8, value9, value10, value11}
local Status1= 0
for i = 1, 11 do
    if value1<= StateAll then
      Status1= Status1+ 1
if Status1== 11 then
    local Trigger1= true
    fibaro:setGlobal('Trigger1', true)
      else
        local Trigger1= false
        fibaro:setGlobal(''Trigger1', false)
I works but I think it is not the proper way to do that check.
Can anyone suggest an easier code?
Thank you
I've checked the impact, you can run it any time you like. On my system (that has a different number of devices than yours) it uses 25-50% percent of one CPU core. I've done a quick test, by putting this in a 100x loop and it did not influence response time (door sensor -> scene > lamp).
There are several ideas and some implementations on this forum, to get around the "changing IDs" problems.
    Nice. Point me in the direction of those ideas pls
