How to set a dimmer to a desired level in a scene
When I build a scen blockscene and use the command "Turn on" then the dimmer turn on the light to the last used level.
But if I use the command "Set value" and use the value "50" (or "100" or "255") nothing happens.
How to do if I want a scene to activate the dimmer to a certain level, e.g. 50%?
The following scene should do the job
