dear all,
i can use the api to create backups for HC2 ??
thanks all
no - use /docs to check what you can find in api.
Basically @up is right, but as in most cases it is possible to look up the action that is send in console. In case of backups it is POST on address:
with payload:
action=create&description=XXX
XXX is backup name.
    ok..thanks a lot
    with payload:
    XXX is backup name.
    Can you give a example, please?
    Scene I use. It is run from an other script, once a week:
    Timeout should be long, because the backup will take some time.
    Any chance of a VD method
    Here you go:
    Here you go:
    Looks almost identical to my attempt that failed... Will compare later see my mistake
    Thank you
    YUP! My code was almost identical...
    My problem is not the code failing BUT my box! It looks like i am the next victim of returning my box back to Poland!
    Attempts to backup for 0:02 seconds then stops!
    phew! that was an easy fix...
    had to put the folder backups back on the HC2 usb stick! why the hell that deleted itself? crazy... saves me sending it back to poland!
    Did you do  this with a Windows OS or a Linux OS?
    You have a similar issue?
    Yes, but for sure another reason
    Will do some more research..
    Keep us posted
    • 1 year later...
    I was also missing the backups map. I solved it whit my macbook.  Now I can finally backup my system. Thank you for the tip @fi-bar-oh
