Hi there,
As you know scenes can be avoided to be instantly executed, simply by using a PIN code check first.
But does anyone know whether you can also put a PIN code check on buttons within a Virtual Device (.. so that the underlying script that actually executes the activation/deactivating of the alarm is not executed before the PIN code input is given)?
I'm using the HC2 by the way
Thanks and best regards,
Mark
