I just received a brand new HC2 yesterday. I plugged it in and downloaded the Fibaro Finder software. It found my HC2 right away and I opened a browser to connect. The HC2 starts loading the page and almost immediately shows me a "503 Server Unavailable" page. I have tried rebooting it several times. I've started in recovery mode and reset the box to factory settings 6 times without any luck. It's only showing me 503 server unavailable
/emoticons/default_sad.png" alt=":(" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" />. I tried to find a few different URL's to see if I could get past the problem, and I can load various php scripts, .js and .css just fine. I was even able to access /reboot.php and actually reboot the box, but it seems to be something wrong with the software.
Is is possible to fix this or do I just have to return the box and get a new one?
I've submitted an official support request, but I have no idea how long it will take to get a response on that one so I'm trying here aswell
14 answers to this question
    Just a small update on this issue. I returned the HC2 and got a brand new one. This solved all the problems! It worked on first boot and I could easily add devices. I have no idea what was wrong with the first HC2 I got, but it was obviously not working properly!
    Good to hear it all worked out....
    Did you try accessing it with another PC?
    Yes I tried from different machines and in different browsers. When I tried the next day, it actually worked when I started the box and left it on for a while.
    But I'm still having a lot of issues with it. I.e. I'm unable to add any devices. I have a support case going with Fibaro, so I'll hopefully get it fixed..
    If it was me i'd return it and get a replacement
    it should work out of the box and you shouldn't need Fibaro support to 'look into it'
    I absolutely agree with you @autofrank! The HC2 is on its way back for replacement now. Yesterday I spent an hour together with a support technician who was logged into my HC2 without being able to get it working. This is not the experience I expect from a brand new device, and I really hope a new replacement will give me a smoother ride. If not, I'll give up on Fibaro..
    I found a solution to this problem without the need to replace the device.
    Ok!? Good for you! What about sharing the solution with others who might run into the same issue :)
    On brand new HC2 4.056 i have got "503 Server Unavailable" page on first boot.
    I tried many different solutions:
    - reboot by power button;
    - reboot by detach power plug;
    - restore to factory default state from the recovery mode;
    - change the browser (Firefox, Safari);
    and all combination of this one.
    But I found that the API (http://HC2_IP/docs) is fully functional. For example, GET /settings/info and other methods.
    So the base system works fine. Thus, the chances of a solution to the problem is.
    After several hours of search (thanks to Google) and meditation - a solution was found:
    1. Authorize in system (we remember that you need to use default account "admin" with password "admin") via the API (http://HC2_IP/docs) by calling any method of the API, which requires authorization. For example, by pressing "TRY IT" on method GET /settings/network.
    Do not close the browser window!!!
    2. After the successful authorization (we saw proper network info) IN THE SAME BROWSER WINDOW AS IN STEP 1 enter in browser's adress line: http://HC2_IP/services/startUpgrade.php
    3. IN THE SAME BROWSER WINDOW AS IN STEP 1 and 2 enter in browser's adress line: http://HC2_IP
    4. You should see the process of updating the system. Upon its completion and restarting the system, the error "503 Server Unavailable" no longer appears.
    • Like 3
    I got this problem once. but, yes, shift-control-del (clear browsing data - check all) solve my issue.
    another way - logging to HC via "incognito mode" in browser.
    These solutions I tried too. But unsuccessfully.
    I had the same thing, I just opened the box, followed the guide and error 503.  Now in upgrade process following VSOKOLOV !
    This seems to work. fingers crossed !
    Thank you SOOOOO much Vsokolov!! This trick worked for me, finally I can connect to my HC-2 again after struggling with it on and off for months!
