rsjabbens 1
I have a problem using the Fibaro Dimmer 2 (FGD212 V3.3).
I have a switch downstairs and one switch upstairs that control the same light at my entree downstairs.
I configured it using the scheme below, i found this on a website. I placed the module at the light bulb. But when i turn on the light, it keeps blinking. I started with a 13W dimable LED bulb, and afterwards i used a regular bulb (not sure about the W, but i think 40 or 60). This has the same result. I use a regular switch, so i changed parameter 20 to toggle switch. I also changed parameter 32 and enabled the on/off mode to disable dimming. And i set parameter 40, the general alarm to no reaction. All with the same result.
What could be wrong? Do i need a bypass for the dimmer? Or did i configured it wrong?
So i connected:
L to the Live wire
O (wave and arrow sign) to the light Bulb and also to N on the dimmer
N see above, is connected to O on the dimmer
S1 connected to first switch
Any help is appreciated.
4 answers to this question
