Energy manager connected to a smart meter, Values in a VD
Just started with the HC2 and for sure completly new to LUA.
I already had an Iungo Energy manager to get the usage on electricity and gas from the smart meter, and also the water usage.
At this stage I managed to get a reponse from the energy manager, but didn't succeed to get the values for use in a virtual device.
I hope someone can give me a suggestion to put me in the right direction on how to get the values from the response.
Response received is:
[DEBUG] 15:07:30: 200
[DEBUG] 15:07:30: 0
[DEBUG] 15:07:30: ENCODE RESULT :"{\"ok\":true,\"type\":\"response\",\"time\":0.001937499968335,\"rv\":{\"propsval\":[{\"id\":\"name\",\"value\":\"Smart meter\"},{\"id\":\"usage\",\"value\":362},{\"id\":\"T1\",\"value\":4113.167},{\"id\":\"T2\",\"value\":2884.556},{\"id\":\"-T1\",\"value\":0},{\"id\":\"-T2\",\"value\":0},{\"id\":\"L1I\",\"value\":1},{\"id\":\"L1Pimp\",\"value\":0.362},{\"id\":\"L1Pexp\",\"value\":0},{\"id\":\"c_tariff\",\"value\":2},{\"id\":\"gas_usage\",\"value\":0},{\"id\":\"gas\",\"value\":1681.49},{\"id\":\"Cost-T1\",\"value\":0.2166},{\"id\":\"Cost-T2\",\"value\":0.2166},{\"id\":\"Cost-nT1\",\"value\":0},{\"id\":\"Cost-nT2\",\"value\":0},{\"id\":\"Cost-gas\",\"value\":0.597},{\"id\":\"Client-blob\",\"value\":\"\"},{\"id\":\"available\",\"value\":true}]},\"systime\":1456149950,\"seq\":1,\"error\":false}"
    Thx, it works...
    Nice one Twan.
    Looks like the weather isn't that bad today in Tilburg at the moment
    Love the Iungo as a gateway for electricity, gas and water measures, and the capability for integrating EV charging stations and heat pumps.
    Jack
    Hi Jack,
    Do you have the solution for the VD, that stops reporting after xx minutes.
    My VD stops after 40 minutes, when I open and save it's ok.
    I use no other meters, so my code is not so big.
    Twan
    -- Virtual Device: Get data from Iungo Energy manager
    -- Version       : 1.3.1
    -- Release Date  : 1.3.0  13 March 2016
    -- 15-3-2016 : 1.3.1  Added new devices
    -- Compatibility : Home Center 2, v4.070
    -- www.iungo.nl
    -- <ipiungo>/iungo/control?cmd=api_list
    --SMARTMETER 538d72d9
    local smartmeter= Net.FHttp('192.xxx.xxx.xx');
    response,status,errorCode = smartmeter:POST("/iungo/api_request/", '{"seq":1,"method":"object_list_props_values","arguments":{"oid":"538d72d9"}}')
    local jTe = json.decode(response)
    usage = jTe.rv.propsval[1].value
    T1=jTe.rv.propsval[2].value
    T2=jTe.rv.propsval[3].value
    T1r=jTe.rv.propsval[4].value
    T2r=jTe.rv.propsval[5].value
    gas_usage=jTe.rv.propsval[16].value
    gas=jTe.rv.propsval[17].value
        ETotal=T1+T2-T1r-T2r
    ZTotal=T1r+T2r
      -- fibaro:setGlobal('IungoUsage', usage)
    if usage <0 then
          fibaro:call(595, "setProperty", "currentIcon", "1013")
        else
    if usage >0 and usage <737 then
          fibaro:call(595, "setProperty", "currentIcon", "1012")
         else
           if usage >736 and usage <2209 then
             fibaro:call(595, "setProperty", "currentIcon", "1011")
           else
             if usage >2208 and usage <3681 then
               fibaro:call(595, "setProperty", "currentIcon", "1010")
             else
               if usage >3680 and usage <5153 then
                 fibaro:call(595, "setProperty", "currentIcon", "1009")
               else
                 if usage >5152 and usage <6625 then
                   fibaro:call(595, "setProperty", "currentIcon", "1008")
                 else
                   if usage >6624 then
                     fibaro:call(118, "setProperty", "currentIcon", "1007")
    -- deviceid 595 Iungo dit VD nummer
    fibaro:call(595, "setProperty", "ui.Label1.value", usage.." Watt")
    fibaro:call(595, "setProperty", "ui.Label2.value", T1.." kWh")
    fibaro:call(595, "setProperty", "ui.Label3.value", T2.." kWh")
    fibaro:call(595, "setProperty", "ui.Label4.value", T1r.." kWh")
    fibaro:call(595, "setProperty", "ui.Label5.value", T2r.." kWh")
    fibaro:call(595, "setProperty", "ui.Label6.value", ETotal.." kWh")
    fibaro:call(595, "setProperty", "ui.Label9.value", ZTotal.." kWh")
    fibaro:call(595, "setProperty", "ui.Label7.value", gas_usage.." m3")
    fibaro:call(595, "setProperty", "ui.Label8.value", gas.." m3")
    fibaro:log("Td: "..T1.." - Tn: "..T2.." - Zon: "..ZTotal.." kWh - Gas:"..gas.." m3");
    fibaro:debug(usage)
    fibaro:sleep(1000*5) --wait 5 second
    Hi Twan
    I had the same issue in the beginning.
    The first part of the code needs to be the following
    if(HC2==nil) then
    HC2=Net.FHttp('xxx.xxx.xxx.xxx'); --IP Address Iungo
    else
    and then at the end of the code you need to add:   end
    See the code you posted with the changes below
    mmm, get this error:
    [ERROR] 15:39:37: line 7: attempt to index global 'smartmeter' (a nil value)
    Strange; at line 7 at this moment:
    Sorry HC2 in the first line must be smartmeter
    if(smartmeter==nil) then
    Updated above post
    thx for you quick response....
    When I change HC2 in only this line, its not working.
    Now I make this below, and it runs again, pjoe:-)
    Now hopen its not freeze again.
    smartmeter=Net.FHttp('xxx.xxx.xxx.xx'); --IP Address Iungo
    else
    else
    My response was to quick, and then you make mistakes.
    /emoticons/default_icon_redface.gif" alt=":oops:" /> or forget a part. Sorry
    You already found the correct solution.
    Now it will stay up and running.
    It might stop when you are working on an other VD which runs into an error. Don't know why
    But normaly it will not freeze
    Guest samuelboerhoop
    good topic.
    good topic.
    Thank you
    Dank u
    Yesterday I upgrade the iungo with a 3 phase consumption meter for Solar panels.
    This meter works with a S0 bus, to read the puls for one kWh.
    Now I will show the consumption for this meter with a formula. The consumption output ("Meterstand") give me "21.22383456677899"
    Is it possible, to show the output with 2 decimals?
    I tried this; (from
    topic), but give a error with debug
    fibaro:call(596, "setProperty", "ui.Label2.value", string.format ( "%6.2f", Meterstand.. " kWh"));
    Twan
    or try
    fibaro:call(596, "setProperty", "ui.Label2.value", string.format( "%6.2f", tonumber(Meterstand)) .. " kWh");
    or try
    It's so simple for a Lua expert...
    Thx, It works....
    Twan
    Small improvement, made the VD more reliable, and keeps it running while working on other VD's
    Changed the IP address of the HC2 to 127.0.0.1, 1111
    Removed the authentication"line "HC2:setBasicAuthentication("login","password")
    @chatboy
    As promissed
    Have fun
    Jack
    After reading this... I want to buy a Iungo lite aswell.
    Nice work guys.
    Jack,
    how did you acces the IUNGO API, is there documentation? Where do I find the OID for the connected devices?
    thx
    Henk
    In the post jun 6 from Jack, you can download the VD. Only Change you IP iungo
    See also: http://IP_iungo/control?cmd=api_list --> object_list_props_values
    @twanve, correct, and this works.
    however I would like to extend the code.
    Iungo supports Zwave powerplugs with metering and once connected to the gateway theorie values should also be retrievable from the API. To do that you need the unique OID for that device.
    therefore my question was how you could use the api to retrieve the OID's
    thx for the reaction though.
    see also for examples;
     (sorry it is in dutch for all the international users) Not my personal website, just aan infosource.
    HC2 @ 4.100
    Hue inetgration
    SONOS integration
    Netatmo thermostat integration
    Logitech Harmony Hub integration
    IFTTT integration
    Edited by H.Lourens
    Clarification
