Hi folks,
I want  to configure Yale YDM 3168 door lock with Fibaro Home center lite.
Appreciate if anyone could help me with the steps to do so ??
Regards
Do you have a z-wave module to this lock?
    Yes I do have installed the external z wave module already - ZW EU2.0 CP2-5-5.
    in options menus, switch to advanced mode
    in advanced Menu ...
    Option 3 - Individual credential mode
    Option 1 - Register
      -- option 'register controler' code '80'
    hc Fibaro in learning mode
    confirmed code 80.
    you will see the process of inclusion in Fibaro hc
    look at the instruction booklet on page 13 for menus yale.
    I have configured on HC2, I guess in hcl be the same.
    Option 1 - Register
    confirmed code 80.
    Thanks for the information .
    I tried it with the home center lite and it is working fine.
    Appreciate your response.
    so if i am right
    you must need a external zwave device
    only a Yale YDM 3168 does not work
    i thought that the Yale YDM 3168 is zwave already
    regards
    so if i am right
    regards
    Yes you are right u should install a z wave module for YDM 3168.
    Yale YDM 3168 is not z wave by itself.
    Arun Kedlaya
    Why is it calling ?
    Z-Wave Lock Yale Monoblock YDM3168
    what z-wave module do you need
    YDM3168 don't have buit in z-wave module. You must add z-wave module (green little box).
    So YDM3168 is not z-wave but with ZW EU2.0 CP2-5-5 you can integrate it ?
    How?
    You can buy YDM3168 with z-wave module or not.
    You can see this here:
    • 4 months later...
    Hi
    Can you use pin codes as well or only normal lock unlock with this Yale in HCL?
    • 7 months later...
    hi guys....i have YDM3168 and also the same z-wave module which mentioned above....same way i added lock to home center but the problem is i can't control lock from fibaro home center.....i don't know why.... i tried alot of time....add to fibaro home center and again deleted from fibaro but it's not working....any help???
    I Have a Yale ZWave lock with and HCL works great (only have local and unlock though). Using Unlock to turn off alarm
    Touchscreen Digital Deadbolt - SYEDDB/220/NZ Wave module installed
    Good day I have a YALE lock of ASSA ABLOY YRL221-NR-619, which when including it is not configured properly for lack of Templates, I already sent the template to FIBARO and I understand that they will include it in the following updates, I would like to know if Is there any way to configure it manually while there is technical support response.
    no I can't get mine to work correctly either :(
    My problem was that when I put the lock on the FIBARO system it did not trigger when sending commands.
    It had as a guide a tutorial of a version of the old Fibaro OS. In this one was selected in the option to add devices the characteristic "The Device is located far from the Home Center". After several tests I decided to check the options "NWI - Network-Wide Inclusion" and "Add in security mode if device supports it", this way the system is included allowing control of the device, even if the témplate is not available.
    did that improve the situation? I have only ever done..
    and whilst it starts to include it...and kinda works...after a couple of days it stops working.
