I have already created some scenes and virtual devices and they are working, I will leave it in tests and I will be commenting.
  • 2 months later...
Hi Santiago,
Glad to read your topic. I have some similar problem with Popp door lock. It needs to be included in security mode but you cannot change Parameter 0 afterwards and you cannot add the device in a scene. this last point very deceiving one. Did you manage somehow to move forward with your topic? To find a solution? Thanks
Br
Mine seems a little more stable with the latest software releases but still have to ensure that the door lock is the LAST in any sequence of device commands in a trigger for it to work.
  • 10 months later...
On 2/25/2016 at 3:21 PM, rls46 said:
in options menus, switch to advanced mode
in advanced Menu ...
Option 3 - Individual credential mode
Option 1 - Register
  -- option 'register controler' code '80'
hc Fibaro in learning mode
confirmed code 80.
you will see the process of inclusion in Fibaro hc
look at the instruction booklet on page 13 for menus yale.
I have configured on HC2, I guess in hcl be the same.
where i found this option on yale lock or in fibaro gateway
in the lock
  • 1 year later...
Hello
i bought the ydm3168, massive thing ?
followed the registration too
Option 1 - Register
But than nothing happens, can't confirm code 80
my z-wave model is SD-M-100 z-wave plus
hi Kage, by option 3 inclusion, do you mean security mode? most probably your door lock shall be included in such way.
It works until I press 80 in too ydm3168
Then nothing not on ydm 3168 or fibaro.
But think it is the module it self. Bought a new one and will try this. Let you now!
  • 1 month later...
Thanks to @rls46 I finally managed (after 3 years of semi random trials) to include this lock in the zwave network controlled by HC2.
I can now open and close, and I can see the status change in HC2.
Anyone found a way to manage PINs? That would be very useful for me (I use the lock in a B&B).
I tried to use the Synchronization function, but it keeps trying without ever succeeding, I suspect the Fibaro template would help, but they'll take years...
  • 8 months later...
 Have you tried new one and it works?
Edited by AboMeshari
  • 2 months later...
yep works great now
