I am currently on v4070, but I think since v4056 that my Fibaro Relays have had an issue where the parameters do not appear correctly i.e. parm 14 looks like this:
Parameter 14
Device On / Off after power cut. Default setting - OFF9
0 - Momentary Switch
1 - Toggle Switch
Default Value
Parameter 14
Temperature Alarm set for Relay 1. Default Setting: device ON after alarm.54
0 - Toggle Switch455
1 - Toggle Switch456
Default Value
Now this might just be a coincidence, but since v4056 I have noticed that parm 13 is no longer working as expected.
I have set it to value = 1, but the relay does not report the status of the device.
I would expect that if there was a live current passing through the relay it would report as on and vice versa if there is no current it would report as off. Instead it seems to stay off most of the time and occasionally report on, however I can't figure out what makes it change.
On versions prior to v4056 this was working perfectly.
Is anyone else experiencing this problem?
Regards
Aleks
