PopUpService + icon upload to VD with LUA
is there any chance that this service should work like a normal pushmessage to iOS? Like now you need to open fibaro app first to see that you have receive a popup.
Also, is it possible to upload icons to an VD with LUA code? I would like to update an VD with actual weather icon.
11 answers to this question
Not mine but you can see example
    But Net.FTcpSocket does not work from a scene....
    Create button in VD which does what you need, a press-it from scene
    /emoticons/default_wink.png" alt=";)" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" /> I would create change Icon button in VD, put icon path to global variable, press buttin, VD gets path from global, set global to nil, put icon to hc2, change VD icon.
    You can also create queue
    Sounds like a plan
    I get this far but no icons uploaded...
    Here is my code
    I have limited access to my HC2 (this week only)
    Try to add:
    Like this?
    I suppose it is not working ?
    Nope
    Tomorrow I will try to find working version and add it to this topic. I don't use it any more, that is way you need to wait.
    hi all, you try my code
