Hi All,
I'm trying to implement this solution on my HC2 with the newest firmware 4.120, and it crash my HC2 , every time when executing the code HC2 displaying me website where i can restart or refresh page. Any idea ?
i only want to delay sprinklers :)
SOLVED
Edited by domin12
  • 1 month later...
How did you solve the crashing? mine is crashing too..
Hi @domin12 and @lroovers,
are you using this code:
or original code from Vesternet?
Hi Sankotronic
Yes, I'm using this code exactly.
Hi lroovers
The answer to your question is in this post. This code works fine with my HC2.
Edited by domin12
Guest AxelS
Hi Guys and "LUA cracks",
is there a possibility to add a label with the next watering time to to VD, e.g. Next Watering: Wednesday 06:00am?
Best
Axel
Edited by AxelS
  • 1 month later...
Here is my little contribution to the sprinkler control topic.
The attached virtual device allows controlling the Sprinkler Panel parameters (so that you can define your own complex scenes tied to e.g. a Popp rain meter and any thermometer) and is compatible with the most recent Fibaro HC2 API (version 4.130).
It is inspired by the Vesternet solution cited many times before, which unfortunately does not work anymore and causes HC2 restarts, probably because of the changes in the undocumented features of the API.
Please take in consideration, that my solution also uses an undocumented API features (mainly: using PUT to change just the adjustWater and rainDelay parameters, as hinted by other users before - neither of these are documented in the api listed at http://[your.h2c.local.address]/docs ) and it may stop working in the future. But it works now :)
Oh, the Fibaro API now REQUIRES the superadmin account (because of the PUT request). I always try to avoid that (instead using a dedicated "api" user with limited privileges), but in this case there does not seem any other way.
You need to set the account in the code of the "Submit" button (clearly indicated).
My VD is a bit more complex than in the Vesternet solution in order NOT to repeat the user/password sections (and reduce boilerplate code). Instead, I keep the values to submit to the panel in the sliders (that is why they are important, as is the "submit" button). A little bonus of this solution is that you can use the sliders to manually modify the adjustWater and rainDelay parameters if you like.
Have fun!
qnstie
Edited by qnstie
Correction of VFIB
qnstie in your device you forget to change password and login :)
@qnstie, please post the VD in here
  • 6 months later...
Guest sameri
Hi guys. I hope it's ok that I'm posting this in an older topic and apologies if this has already been answered but was wondering if there was a way to switch the individual sprinklers between Auto/Off using a VD or similar?
I'd like to be able to effectively disable my sprinklers during winter and only water automatically during summer.
  • 5 months later...
I have the same question.. for the life of me, I can't work out how to set the mode to auto or off.. I am able to set the raindelay without a problem...
OK.. this code works for me.. I have a VD with 2 buttons on it.. Auto and Off.
The below code is for Off.
____________________________________________________________________________________________________________________________________________________________
-- Set authentication
HC2 = Net.FHttp("xxx.xxx.x.xxx",80)
HC2:setBasicAuthentication("xxx", "xxx")
response ,status, errorCode = HC2:GET("/api/panels/drenchers")
jsonTable = json.decode(response)
dr = jsonTable.drenchers
for i = 1, #dr do
    fibaro:debug("Device : " .. i)
    fibaro:debug(dr.id)
    fibaro:call(dr.id, "setDrenchingMode", "auto")
selfId = fibaro:getSelfId()
fibaro:call(selfId, "setProperty", "ui.lblSprinklerStatus.value", "AUTO");
Do the same for Auto with the Value of Auto.
Edited by rajp
Guest sameri
for i = 1, #dr do
fibaro:debug(dr.id)
fibaro:call(dr.id, "setDrenchingMode", "off")
fibaro:call(selfId, "setProperty", "ui.lblSprinklerStatus.value", "OFF");
Yours looks better than mine ended up. I had another post here with my thought process:
I have uploaded the answer there too. Not sure why, when I upload my script which has square bracket, it removes that. The code looks like below screenshot.
