hetbeest 0
Hi all,
I've been searching and reading in this forum and haven't found my exact problem and it's solution just yet.
I have a dimmer 2 (fgd212) connected to 5 Pharox 4W led bulbs. I've bridged the leds with the Bypass 2. I've got a dual momentary switch connected to the dimmer, just like in the Fibaro manual, see the attachment. The dual momentary switch is connected with leads between 5 and 10 cm. When I connect the dimmer to power, it starts calibrating. The leds go in increments from off to full bright, so the dimmer is able to get the leds at different light levels. After calibrating the leds get stuk on a single light level, I guess something like 30%. The don't switch off, they don't burn at full level, not through the HC2, nor with the momentary switch. I've looked at all parameters, changed them, did exclusions and reinclusions of the dimmer, etc. No luck. I connected the dimmer to a old fashioned light bulb, not using the bypass, furthermore the same setup. I just had to enable the S2 switch in the settings and it works flawlessly. What could be wrong with the led setup?
Thanks in advance,
Evert
9 answers to this question
