Simple Variable Trigger Scenes Not Working - Please Help, Please
Hey guys,
I have some simple LUA Scenes that simply don't work unless I manually click RUN. Any help would be appreciated.
Secondly, this "Goodnight" scene, breifly turns ON the lights, before turning them off??? I also have to manually run it twice before it updates the variable?
The all lights OFF scene works perfectly by itself.
I have a feeling I'm missing some basic understanding, thank you for your help.
Jamie
Link to post
5 answers to this question
Are your scenes activated? see below
Link to post
  • Yes, all activated... Although I just noticed there is nothing listed under the "triggers" on the block page.
    Surely someone has made a working scene using LUA? I've found this..
    %% autostart
    %% properties
    %% globals
    local BeforeSunset = 45
    local AfterSunrise = 45
    while true do
        if (os.date("%H:%M", os.time()+BeforeSunset*60) >= fibaro:getValue(1, "sunsetHour"))
        or (os.date("%H:%M", os.time()-AfterSunrise*60) < fibaro:getValue(1, "sunriseHour"))
          then
            fibaro:setGlobal("nightTime", 1);
          else
            fibaro:setGlobal("nightTime", 0);
        fibaro:sleep(60000);
    It looks easy enough to change for what I want, but surely the graphic block scenes I've created should work?
    Link to post
    %% autostart
    %% properties
    %% globals
    while true do
          then
          else
    First of all scene based time triggering doesn't have any triggers, it  just runs in continuous loop.
    If you will convert your block scene to LUA you'll see function tempFunc(), which is executed every minute by calling
    setTimeout(tempFunc, 60*1000)
    Your scene should work and change your Global variable....
    What I can suggest is to convert the scene to LUA and put some message using fibaro:debug() to see what happens.
    Your message should be printed every minute.
    Link to post
    This is similar to my issue that i am having on my HCL. if you search "Trigger lights between a range of times" you can find my issue.
    in my latest post i said:
    "I have tried everything and it still is not working. i even contacted support and they are not helping. This should be a simple scene but it has turned into many sleepless nights "literally". The only time it "kinda" works is when i run the inactive scene manually. but then if someone triggered it at 4:00 am the lights will come on even though i told the active scene to activate at 8:30. any help would be appreciated."
    Link to post
    Could you post all your scenes involved in this process.
    For example you have posted scene based on GoodnightScene variable, but where the scene which changes the value to OFF?
    Link to post
