markdyer 1
Hi, I have a 3 clamp HEM and it shows me the TOTAL and Clamp 1-3. I have the clamps setup as follows:
Clamp 1 House (Phase 1)
Clamp 2 Garage (Phase 2)
Clamp 3 Hotwater Supply (Phase 2 but not included on clamp 2)
I would like to select which Clamp a device is on in the house so the power is deducted from the correct clamp total.
I would then like to have a total power use of the combined clamps with break downs to what used the power and how much is used that is not accounted for.
It doesn't seem like rocket science so hopefully some one has worked a way around this or does Fibaro need to add a new field to each device which assigns it a clamp.
End result how can I report the power used on each clamp without duplication of the usage..
