I am new here and need your imput to setup a wireless home automation systems which include
1) 8 zones of Audio which include ( 2 x Living room, 3 x bedroom, 1 x kitchen, 3 x bathroom.
2) 5 zones of lighting control with dimming
3) 1 unit of window control.
I want to be able to use fibaro systems and app to control all.
I need help to choose the right lighting, electric curtain track and multi room audio systems to effectively work with Fibaro
Sonos is easily the most supported system, but if you search this forum you will see lots of debate about other systems
Fibaro Dimmer 2 seems to work with most light bulbs. I use Philips Dimtone LEDs which work well.
Fibaro Roller Shutter 2 and with Somfy motors works well
TBH: You need to search the forum. There is a tonne of info out there to answer your question in more detail.
