Morning all,
It's been a while since I have seen any chatter about the Broadlink devices. Has anyone created a virual device or further thoughts on integrating the Broadlink IR / 433 blaster???
Edited by T.Konopka
Wrong caterogry
42 minutes ago, Phenix said:
Well I managed to get it to work by using LUA Code - Eureka moment
local selfId = fibaro:getSelfId();
local ip = fibaro:get(selfId, "IPAddress")
local port = fibaro:getValue(selfId, "TCPPort")
local url = "/code/Lounge Blind Up"
local ws = Net.FHttp(ip, port)
local resp = ws:GET(url)
fibaro:debug(resp);
Don't forget to put _ between the code
eg. Lounge Blind Up needs to be
Lounge_Blind_Up
On 5/13/2018 at 7:55 PM, India221189 said:
HI Everyone,
I have just got the RM Pro but i am not able to use in Fibaro Virtual Device. There is no response but when i use the HTTP Code Directly. I am able to run the command. I have followed all the steps. Please help.?
Let me know if you need help - but I managed to crack it as my above post.
You should use LUA code in HC2, sadly you cannot use LUA in HC2 Lite
  • -1
HI Everyone,
