morpheus75 77
i thought i would share a little VD i made coz i am a bit lazy when it comes to my Sonos.
i created some playlists and saved them as .m3u files and each one is about an hour long. i then created a VD to select my speaker and then i sent the playlist path to it, set the initial volume and it just plays it all and turns off. No other input is required.
you can pause/unpause and stop if required and adjust volume if needed.
This VD requires the krikroff VD and sonos remote to work properly.
to make it easier here is a short video :
and the VD is attached.
