chubbyyz 0
Now that the weather is getting warm in this part of the world, I am trying to get the "AC Panel" configured, but I cannot get it to work.
During winter, I configured the "Heating Panel" and it worked perfectly. So I followed the same steps to configure the "AC Panel":
...but the panel never changes the temperature in the thermostat at the expected times of the day, so it never triggers the air conditioning to turn ON.
I also tried forcing the air conditioning to turn on by using the Holiday mode and the Manual mode, but nothing happens on the thermostat.
However, I can manually set the temperature from the "Devices" screen on the HC2, and when I do it this way the thermostat receives the data and it turns on the air conditioner, so I know that the thermostat is configured properly, so either I am missing a step or the AC Panel is not working.
Has anyone been able to get the AC Panel to work?
My HC2 system is running version 4.082
My thermostat is Honeywell TH8320ZW
4 answers to this question
