Has anyone added an Aeotec Smart Dimmer 6 Gen 5 ?? when I add it using the mobile interface it says that the process has failed but when I check on the web interface it shows the device added several times.
Its working but its weird
Hi Fibaro
7 months ago a member of this forum made you aware that it is not possible to configure the The Aeotec dimmer 6 device.:-(
7 months is a long wait - it would be super with an update?
:-D:-D
Indeed, seven months without dimmable lamp :-?
Mine works perfect, just not configured and a total of 8 devices.
p.s. I'm on 4.110
Mine also works. The problem is I cannot control it from any scene since the device isn't configured.
The only way to use it is by switching it manually in the app or via the portal.
So yes, you can turn it on/off, but you can't use it in any scene. And that is exactly the reason we have our Fibaro HC in the first place.
So please dear Fibaro devs, help us!
Jelle
(I have a HCL on 4.110)
Works, I use @Sankotronic very smart ight scene and works perfect for me.
HC2 4.110
Thank you!
But I have the HCL which doesn't have LUA.
So I only can make scene's with the block diagrams.
And with the blocks I cannot select the aeotec dimmer :S
(I think it is because it isn't configured)
So again, please Fibaro devs, help us.
Yes, you are right. Just checked and you can't use it in block scenes
Hi Fibaro
:-D:-D
Hello Fibaro,
Is there any news on the support for this dimmer? As it is also not possible to use it in block scenes. We have several costumers who cannot use this device in the Fibaro Home Center Lite and 2
Edited by stevenvd
It would be nice to have this device configured...
I can use it in block scenes through a virtual device, but the delay is really annoying.
The Aeotec dimmer 6 device is still not configured  in update 4.120 :-(:-(:-(:-(
Dont you care about your customers?
Still no feedback???:(
Dear Fibaro, we have now been waiting 11 months for an update.:(
It would be great with an update allowing os to configure the The Aeotec dimmer 6 device.:)
On 28.3.2017 at 9:48 PM, severin said:
The Aeotec dimmer 6 device is still not configured  in update 4.136
Wie ktoś co zrobić by ten dimmer zaczął działać??
Kupiłem smart dimmer 6 i .... wogóle nie chce on współpracować z Fibaro..
Działa cały czas niezależnie od tego czy go ściemnie, włącze lub wyłącze. Prąd idzie cały czas.
Kupiłem nawet zsticka by ugradować go do wersji 1.07... bez rezultatu.
Jedyne co robi poprawnie to liczy napięcie i natężenie prądu. Nie spełnia jednak swojej podstawowej funkcji czyli nie odcina prądu...
I've just bought an aeotec smart dimmer 6 and it is not configured with my HCL 4.530 and it doesn't work (neither ON/OFF lamp).
Does anyone resolve this problem?
HI Fibaro,
When I see  how much you care for your Customers who gave good money to buy your stuff. I seriously thing of switching to open source solutions like OpenHab!
And maybe if enough of us do the same you will then take customers support into consideration !
Guest Oz9els
Any news.. It gets a bit boring without a comment from the dev team...
It is now 2020 and an issue flagged in 2016 has apparently not been resolved.  Fibaro, it seems a lot of people are waiting for this to be resolved..
