Showing results for tags 'smart dimmer 6'.
  1. Has anyone added an Aeotec Smart Dimmer 6 Gen 5 ?? when I add it using the mobile interface it says that the process has failed but when I check on the web interface it shows the device added several times. Its working but its weird
  2. Hi, I have a some Smart Dimmer 6 modules from Aeotec which are connected to a HCL (v4.160). Including and switching/dimming works OK, but I cannot use them in a scene (graphical). Is there any way, that can be solved (e.g. by adding the template manually)? Thanks. Willem-Jan
