Does anybody know if it is possible to run a scene to and extract a 'result from there scene via the API
An example might be to check which sensors are triggered or zones are open/closed and just return open ones.
I'm pretty sure I could run the scene and update a global variable and then just use the API to read the value of the global variable but I was wondering if there was a way to do it with just the scene
-F
Guest chaicka
I am sure I ain't knowledgeable enough to be certain in answering. Based on what I know, variables are localized within the scene, not beyond which is why the inclusion of global variables (after early betas of v4.x) and many scripts/scenes shared in this forum use the gbl var approach.
I could be totally wrong though.
