Hi guys
I have problem. Actually Fibaro Double relay switch is weak in case of halogen because of inrush current and arcing at the startup.
1-Which brand do you offer to use instead ?
then, I decide to use philio pan04, but it has 1sec delay at the mechanical switches. I mean after you change the momentory switch on the wall, after 1sec lamp turnes on and you see that statuse on the application.
2-How can I solve this problem ?
3-Furthermore, I've heared that no more than 12 pcs of philio relays work with HC2 together. Is it right ?
Thanks in advance for answering
Link to post
