I have a strange problem with the fibaro door sensor.
It is connected to an external switch and has the sceneActivation on. By switching the external switch the scene gets triggered and everything is fine, but the breach time is not always updated. At the moment the system shows that it was breached 1 day ago, but the scene was triggered just minutes ago.
Is there anybody who had the same problem?
Guest chaicka
I am under the impression that door/window sensors' breach time is based on the magnetic breaching of the sensor itself, not the inputs (connected to switch or other methods/devices). But I could be wrong too.
    well, I have the same problem with the door sensor in his normal (magnetic switch)  function. At my front door the sensor shows last breach yesterday although the door was opened just minutes ago. Can it be that the sceneActivation disturbs somehow the breach time parameter?
    And additionally this wrong breach time is coming only from time to time. not always.
