[SOLVED]Firmware update problem: FGMS001 Motion Sensor EU
For some reason I can not update the firmware of my FGMS001 Motion Sensor EU.
It's using 2.7 at the moment and want to update to 2.8.
All looks fine, and I even get the message Success.
Status: Available
Current version: 2.7
Available version: 2.8
Status: Updating...
Status: Success
[23:23:53] ID 188: New image was successfully stored in temporary non-volatile memory. The device will now start storing the new image in primary non-volatile memory dedicated to executable code. Then the device will restart itself.
However. It keeps showing version 2.7!
Even after reboot.
Status: Available
Any suggestions on how to fix this?
11 answers to this question
Tried waking and triple click?
    Yes. I did.
    To start "wake up" I triple clicked and it started updating. 1/2 during update I needed (as described in the documentation) to triple click again to continue update.
    Log file shows that update has been done, and that all is fine.
    try "soft reconfigure" before update, that worked for me.
    Thank you.
    Will give it a go tomorrow and report back.
    Now it's time for some sleep!
    Welterusten.
    Guest chaicka
    Check out this thread and it may shear some light on what you are facing...
    On a side note, did anybody tried to update a device without moving it within 2 meters of the HC2?  I tried but no luck
    /emoticons/default_sad.png" alt=":(" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" />  And all my motion sensors are hard wired and kinda difficult to move...
    Guest chaicka
    I did and found success.
    ~3-4m with 2 concrete walls (1 concrete wall with BRC mesh inside, 1 brick wall) in between.
    /emoticons/default_wink.png" alt=";)" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" /> It takes longer time to transmit the 'data' over.
    Hard-wired? Hmmm...modified setup?
    No batteries
    Guess i'll have to retry then..
    Guest chaicka
    Tip: Disable scene(s) that use the FGMS001 first. In my 2 rounds of firmware updates (2 x 6 of them), scenes seem to interfere and fail update. Oh, wake up interval does too, if my recollection serves me well.
    This worked for me
    Thank you for the link chaicka
    Is there a list of new features or bugfixes with the new software versions?  All of my light dimmers are in version 3.2 and version 3.4 is available, but before getting it out of the wall I really need to know what is fixed or which new features there are.
    Otherwise I let them stay and work!
