Z-WAVE
Fibaro
  • 1 x HC2
  • 23 x Fibaro Relay FSG221
  • 13 x Fibaro Dimmer FGD211
  • 1 x Fibaro Motion Sensor, GMS-001
  • 3 x Fibaro Contact Sensor FGK101
  • 2 x Fibaro RGBW Controller FGRGBW-441-R
  • 5 x Fibaro Universal Binary Sensor FGBS321
  • 1 x Fibaro Swipe
Aeon
  • 1 x Aeon Smart Switch Heavy Duty (9kW)
  • 1 x Aeon Multi Sensor MS5 (currently faulty)
  • 1 x Aeon Home Energy Monitor
  • 14 x Aeon Multisensor 6
Everspring
  • 5 x Everspring Motion Sensor SP102
  • 2 x Everspring Motion detector SP814
TKB
  • 7 x TKB Double Dimmer
  • 1 x TKB Single Dimmer
  • 3 x TKB Double Switch
  • 3 x TKB Single Switch
Remotec
  • 2 x ZRC90 scene controllers
Philio
  • 1 x Philio Smart Relay (used to power meter and switch 2 equipment racks)
  • 1 x Philio Remote Smart Colour Button
SwiidInter
  • 10 x Swiid Inline cord switch
Security
  • Siemens SPC Alarm System with full HC2 Integration via SPC Gateway on Dragino
Other
  • 1 x Nodon Octan Remote
  • 2 x Aeotec remote Minimote
  • 21 x DS18B20 Temp Probes
  • 4 x Pogo Plug in wall switch
  • Raspberry PI running sonos-http-api
  • 2 x Remotec ZRC-90 Scene Controllers
  • Open Remote Controller for Custom UI's
SYSTEM DIAGRAM
NON Z-WAVE
Sonos & Amps
  • 1 x Play 5
  • 1 x ZP80
  • 2 x ZP90
  • 1 x ZP100
  • 1 x ZP120
  • 2 x Play 3
  • 6 x Play 1
  • 2 x Behringer EPQ304 Europower 300W
  • 12 x BluCube 8” Ceiling Speakers
Cameras
  • 4 x Trendnet TV-IP311PI IP Cameras with PoE
Network & Power
  • Netgear JGS524S 24 Port Gig Switch
  • 2 x Ubiquiti Access Points (UAPACLR)
  • 1 x Ubiquiti Security Gateway (USG)
  • 3 Surge protect APC Power Strips
  • 3 x 24 port keystone (Cat6a/F-conn) patch panels
  • 2 x Netgear 8 port Gig switch
  • Wifi-Texas 8 Port PoE hub (for tablets and some sensors)
  • 350Mb FTTH broadband
  • Global Cache GC-100-12
  • Global Cache GC-IRL Learner Unit
Media, Sources & Tablets
  • Humax Freesat Box with custom firmware
  • Sony BluRay Player
  • Apple TV Gen 2
  • Apple TV Gen 3
  • Android TV Box – NPET MXQ Pro TV Box
  • HDAnywhere 4x4 2K HDMI Matrix
  • Synology NAS – DS415Play (8TB)
  • Zxtel NAS NS310 (2TB)
  • Samsung Galaxy Tab 4 7” - Playroom
  • Samsung Galaxy Tab 4 10” - Kitchen
  • Insignia Android Tablet 10” - Landing
  • iPad Gen 2 - TBD (for demopad)
  • iPad Air2 - TBD (for demopad)
  • Global Cache GC-100-12 Network IR
  • 4 x Various TV's (Smart and dumb)
  • Optoma HD27 Projector
  • SAM 133" Electric Projection Screen
  • Insignia Flex 8 Tablet - Living Room
Edited by AutoFrank
updating list
Got some screenshot etc of the Siemens integration... I do think the DSC or Satel stuff in Fibaro is good enough from what i have read on forum.
What capabilities do you have with it? ability to dd variables for alarm state? trigger lights etc...
I have found some data... thanks anyway
    That's the one and greta support from Goran.
    The reason I went this route is because I wanted a conventional alarm (with batt backup, keypads, etc) in case my HC2 went down but I also wanted some exposure via the HC2. I can see status of all sensors, zone status, I can set, unset, nightset, etc through the HC2 scenes. All these are mirrored in realtime to the HC2.
    I use the alarm sensors to trigger autolights in rooms at nightime, I also use them to determine occupancy. Everything is http-api based so I can pull it into my OpenRemote panels. There is also some additional info I can get on demand through the api such as zone isolation and inhibits. With these and occupancy I'm working on an AUTOALARM scene so if we forget to set the alarm, the house will determine the lack of occupancy and try and set away mode itself and even if a window is open it will inhibit that and set away mode anyway. The SPC gateway has proven to be very stable.
    I also created a VD to show the basic status.
    Liking the look of this system
    That is a nice touch from a security perspective!
    Where did you buy yours?
    I have the SPC4320 and it was bought locally and installed by a Alarm Specialist.
    It was the only part of my automation setup that I didn't install myself.
    Guest chaicka
    Interesting to see UAP-AC-LR and USG.
    I am running UAP-ACv2 and UAP-AC-PRO + ES24-500W for my network.
    /emoticons/default_icon_wink.gif" alt=";-)" />  Pretty cool stuffs. Catch me in their forum.
    /emoticons/default_tongue.png" alt=":P" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" />
    I didn't know they had a forum, must check that out.....thanks
    The Uni equipment is fantastic, very robust and reliable, It makes the regular wifi gear look like rubbish
    Why did you go with the Pro equipment, did you need the extra range ?
    Their switch is fantastic but I had bought the PoE hubs before the AP/USG
    /emoticons/default_icon_sad.gif" alt=":-(" />, it would have been nice to combine
    I use the draytek 2860ac and a few ap910c they are not bad... Not had to restart them since installation a lonnnnng time ago
     they look  very robust..
    I think the dedicated AP are streets ahead of the regular domestic equipment that have to be bridged
    I have a box full of netgear routers in the garage that make better paper weights
    Guest chaicka
    I think we are going off-topic here...not sure if Fibaro will make noise about it.
    Went for the PRO due to throughput (it's a 3x3 instead of 2x2 for the Lite/LR) and its range is pretty decent (not losing to LR).
    Totally agree on the part where UAPs (price point & functionalities) just make those SOHO-class APs looks like rubbish.
    perhaps but I thought we were just having a 'general discussion' here
    Guest chaicka
    I think going by your posts and mindset, u will love their forum. Give it a try. Oh, if u r keen, u can even become part of public beta testing (not default enrol, need to sign up).
    Fibaro make a noise lol
    • 4 months later...
    List updated at start of post - changes in blue
    Edited by AutoFrank
