DaveScout 1 Share Posted July 18, 2016 Morning all! Been trying to figure all the documentation all last night about Global Variables and the API. I can look at the status of a variable but no idea how to set it using the API? Does anyone know the line for setting Global Variables using the API? Thanks!! Quote Link to post Share on other sites
0 jakub.jezek 265 Share Posted July 18, 2016 In Fibaro it should be something like bellow: PUT HC_IP/GlobalVariables/variableName HTTP/1.1 Host: your_HC_IP Authoriation: basic [username:password in base64] {"value":"your_value":} Quote Link to post Share on other sites
0 DaveScout 1 Author Share Posted July 19, 2016 Hi, thanks for your reply. That seems like what you would put into a virtual device and not something like: http://admin:[email protected]:80/api/callAction?deviceID=63&name=turnOn a one line HTTP command Quote Link to post Share on other sites
0 jakub.jezek 265 Share Posted July 26, 2016 Hi, thanks for your reply. That seems like what you would put into a virtual device and not something like: http://admin:[email protected]:80/api/callAction?deviceID=63&name=turnOn a one line HTTP command Hi, sorry for delay Well, what i posted last time, that is some change of json body and that will properly change a XML file, where i believe are global variables saved. Basicly every informations are in some XML files. I believe there is a transformation from XML to JSON for better working with Fibaro devices o global variables properties, such as creating some VDs where you can change properties of scenes. And i do not know about one line HTTP command. Please, contact fibaro support by a phone and email for some faster response from them if they know something. Quote Link to post Share on other sites
DaveScout 1
Morning all!
Thanks!!
Link to post
