Problem: Password Manager does not offer to save user and password
Most annoyed for me was to enter a user name and password in my browser.  I do not know why, maby Fibaro team specifically done this for security purposes, or it is shortcoming of browsers on chromium. Anyway, i found a little trick how to save your credentials in Opera (v. 38.0 in my case)
Solution: Click Add or remove device -> Add camera (it will open new camera configuration page) -> Fill in the fields camera USER and PASSWORD with your Fibaro controller data -> Instead of press save icon just simply go to the Advanced settings tab and Opera will proposeyou  to save credentials. That's all the magic
Added camera you can delete afterwards without regrets.
Maybe someone else knows another way to do it, but this simple solution works. Did not check in other browsers.
thank you very much for this trick Ruslan !
i use my login page credential in keepas
1Password is what I use
