Magic scenes to turn lights on and off at set times
budda
What's the best way to use the new Magic Scenes capability to turn on a light at 10pm and turn it off again at 1am ?
At present i'm creating 2 magic scenes per light device which seems clumsy.
In the magic scenes options i can see options for "turn off after X minutes" and "toggle state" etc.
I also just noticed once magic scene can be conditional from another magic scene.
I've not seen much talk about this type of scene on the forum yet -- who's using it and how ?
6 answers to this question
  • Assuming nobody uses the noddy Magic Scenes for simple tasks then?
  • use blocks
    on at xx time
    off at xx time
    Do you mean creating a single Block scene to do it ? Or two block scenes?
  • 2 block scenes, you turn on and off on fixed times, so 2 scenes
    So exactly the same as using Magic Blocks for 2 scenes.
    Seems clumsy to me -- needing to create two scenes to switch something on and then set it to go turn back off X hours later?
    you can do this in 1 scene
    light on at 20:00 houres
    lamp off after 7 hours of waiting
    this is a timer running for 7 hours, i guess if you reboot the hc2 in the meantime the timer will be erased and the light will not go off
    i use timers only for pirs, because the time is not fixed, for fixed time scenes i always create 2, one for on and one for off
    Edited by akatar
