Devices is turned on or not.
Hi
Can someone help me please . I just want to find out whether eon devices is turned on or not.
   --"type":"com.fibaro.FGRM222"
local response ,status, error = api.get("/devices/72");
jsonTable = json.encode(response);
devices = jsonTable
fibaro:debug(devices)
for k, v in pairs(jsonTable) do
  result = v.enabled
result = result
fibaro:debug(result)
12 answers to this question
or you could use:
local device = api.get('/devices/72')
fibaro:debug(device['visible'])
fibaro:debug(device['properties']['value'])
id = 72
if tonumber(fibaro:getValue(id, "value")) > 0 then
  fibaro:debug{"Turned On")
else
  fibaro:debug{"Turned Off")
    Hi
    All this I know, but queried via the api whether the device eaktiviert or is visible.
    I can not read because it is Boolean from the table the value.
    As I go through the tabell with the fo..do
    If you want to use the API:
    It works perfectly in VD. Can you adapt it for a scene?
    thank you
    Thank you very much
    fibaro:debug(device['enabled])
    This method works very well and easy.
    How can I set to False????
    • function Device:setEnabled(true)
    thank you in advance
    How can I make a device on the off with script ..
    Hi
    How can I only the timestamp print?
    print(json.encode(timestamp ))
    thank you
    38 minutes ago, parip69 said:
    Hi
    thank you
    local event = api.get('/panels/event?last=1&type=id&deviceID=147')
    print(json.encode(event[1].timestamp))
    Thank you, it works
    Hi!
    device:setEnabled(false)
    Does this function work in scene?
    I cant get it work? Device property setEnabled does not change.
