Sankotronic 2,375
Check status of doors and windows v1.0
This simple scene will send push message every time when door or window is opened if global Variable DoorWinCheck is set to "Yes". Usage, we are sitting in garden on the opposite side of our house main entrance door. Turning this scene on and we will be informed every time when somebody opens main door
/uploads/emoticons/default_smile.png" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" /> If scene is started manually with RUN button or by other scene or VD then it will check all doors and windows (or just those we put in the list) and will send popup message with the list of opened doors and windows. The rest is up to you. Here is scene code:Please login or register to see this code.
global variable DoorWinCheck can be changed by virtual device which have one label and one button. Here is code that goes to button:
And if you want you can add this code to Main loop:
Don't forget to change name for label from label1 to lblDoorWinCheck or vice-versa. Here is also picture of DV and icons to use for scene and VD:
EDIT :
New version 1.0 with some changes for users to easier setup. Now you can use existing variable and values you just need to enter name of your variable and map your values to Yes and No for checking and sending push notification when door or window is opened.
Also changed push notifications so that users are defined in table variable userID. userFlag defines if user will get notification set by 1, or not set with 0. You can add your part of code to change flags, see example:
Enjoy coding!
Edited by SankotronicRelease new version of code
6
6
5
Apr 15
7
Feb 2
4
Dec 31
4
Feb 1
4
Sankotronic 19 posts
Arbu-jl 6 posts
jimicr 6 posts
Gullfrode 5 posts
Apr 15 2017
Feb 2 2017
Dec 31 2016
Feb 1 2017
Sankotronic
Check status of doors and windows v1.0 This simple scene will send push message every time when door or window is opened if global Variable DoorWinCheck is set to "Yes". Usage, we are sitt
Sankotronic
@jimicr, This scene I wrote on one of users request. It is standalone scene. For alarm I have completely different solution but also with checking status of the sensors before arming. I st
Sankotronic
@jimicr, Thank you for your kinds words and that is the best award for my work. Fibaro really doesn't have to do that, but I will not complain if they do
56 answers to this question
