Learning mode error
When i start learning mode i get this message:
[20:30:58] Learning mode error. Try again.
[20:30:58] Adding devices complete
There is also no pop-up with a countdown (like usual).
I already restarted the HC2 several times.
Does someone know how to solve this problem?
I'm using 4.090 Beta.
So I recovered my system and still couldn't add any device. Time to use my brain! Several weeks ago, I added an Aeon Z-Wave stick. Did it assume the role of inclusion controller instead of the HC2? Yes it did: I was able to include my HC2 on the Z-Stick - that wasn't meant to happen! I have limited use for this setup (it served to upgrade the firmware of a MultiSensor 6). I've now removed the controller from the HC2 (I've properly excluded it) and my HC2 is back to normal. LC12 included again, added to the room and updated temperature from the heating panel.
